The garage
Alternator problems
Topic: Alternator problems (Read 4402 times)
Gambit
Forum addict
Re:Alternator problems
Reply #10 on:
17 December 2003, 12:12 »
aye this happens on mine, car just cuts out with no battery power at all.
spooked me the first time it happened
pity im only remembering all this now!!
Helios_Blue_Valver
Reply #11 on:
17 December 2003, 14:49 »
Quote from: Gambit on 17 December 2003, 10:31
test the alternator to see if its charging
haynes (or bentley) tells you how
Another old trick. If you look at the back of the alternator you will see a steel cap that covers the back of the alternator shaft and the rear bearing. with the car running touch that cap with the blade of a screwdriver. If it sticks to it like a magnet than you know the alternator is charging. if not than it is more than likely bad. Check the water in your battery as well. I know it is a new battery but if your voltage regulator is tits up than it could have boiled the water out leaving it dry. Just a thought.
sKrEwBaLL
Here all the time
Reply #12 on:
17 December 2003, 14:52 »
I'll bear that in mind. Looks like the problem is solved now but I'm a bit pished off that I forked out for a battery and alternator which I didnt need. Mental note to oneself: check wiring before buying anything in future
The garage
Alternator problems
