Golf mk2
single headlight conversion
Topic: single headlight conversion (Read 2439 times)
frog
Here all the time
Re: single headlight conversion
Reply #10 on:
07 July 2006, 13:26 »
If your going to do a 2 lamp conversion, to ensure a clear main beam upgrade the loom just the same as you would upgrade for dipped beam
tomocr
Reply #11 on:
07 July 2006, 13:45 »
What do you mean by uprgrading the loom? Do you mean the whole loom? This is starting to sound like a faf.
frog
Here all the time
Reply #12 on:
07 July 2006, 13:59 »
No its not that big a job, some one on here sells ( or use to sell) the looms or make one up yourself.
Click on the link below for full instructions, although the link is for dipped headlights, just follow the same guidelines but switch the dipped wire for the main beam wire and hey presto.
http://www.matey-matey.com/uprated_headlight_wiring.shtml
If you are going to convert i suggest you carry out this for both dipped and main beam, the difference is surprising
Judderi
Guest
Reply #13 on:
07 July 2006, 16:07 »
Dizzie used to make them. Basicly they get the power direct from the battery and yes it does improve the brightness of your lights. No essential though.
Golf mk2
