Author Topic: Radiator fan issues  (Read 2624 times)
Re: Radiator fan issues
« Reply #10 on: 03 July 2006, 15:54 »
l don't think so, but it may be in some strange way linked to the fan, perhaps something to do with the fan over-run switch?  Perhaps the faulty switch was causing an earth problem or a power drain...  Doesn't sound to likly.  The short answer is I don't know :grin:
Judderi
« Reply #11 on: 03 July 2006, 15:59 »
Its happened again! Johnny doesent know an answer to something!
 :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked:
 :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin:
« Reply #12 on: 03 July 2006, 16:02 »
The 16v is my kryptonite, if you will  :laugh:
Maybe you should all put some money together and buy me one so I can learn how they work ;)
Judderi
« Reply #13 on: 03 July 2006, 16:07 »
yeah right. Keep on dreaming 8v boy
« Reply #14 on: 03 July 2006, 16:10 »
Thats 2.0 8v boy to you ;)
Offline MackyM
  • Rollin' back the years...
« Reply #15 on: 03 July 2006, 21:27 »
I have a theory that actually my car isn't really running hot and the fan is kicking in when needed. I noticed that my indicated oil temperature depends on what position the interior fan is set to!  For example, when the interior fan is off the indicated oil temp might be 100C - position 1 would be 102, 2 would be 104 and 3 would be 106C!!! It literally changes the very instant you touch the switch  I guess as the current/resistence changes somewhere. I have the fan on in the hot weaether and it looks like my engine is cooking - I turn it off and the engine looks fine and I'm cooking instead. Presumably the fan switch is unaffected by this nonsense and is kicking in when it probably should. What could cause all this nonsense? Poor earthing somewhere?
« Reply #16 on: 03 July 2006, 21:30 »
Yeah sounds like it, check the braided earth cable from the coil bracket to the side of the engine, and look under the dash under tray at any earth (brown) cables to make sure they haven't come adrift.  May be worth pressing on the clock plug in case it aint on all the way as well :)
Offline MackyM
« Reply #17 on: 04 July 2006, 14:59 »
All the earthing seems fine except for the missing strip on the bonnet edge. I guess I need to take it to an auto electrical place.
« Reply #18 on: 04 July 2006, 15:17 »
before you do that, take all the earth connections off in the engine bay and clean them up with a wire bruch/sandpaper till they're nice n shiny.  I'd also do the battery & alternator wires too while you're there :)
