Author Topic: Electric mirror wiring  (Read 1253 times)
Offline Red8v
« on: 29 June 2006, 12:11 »
Hi I have just purchased some heated electric mirrors and need some help with wiring them in. I need to know how to connect them to the fuse box. I assume they will wire into there, i've got the original loom but no relay do I need 1? This is a pic of the connector that I assume should plug into the fusebox
At the same point on the loom I also have these wires any ideas? Why is the white green one cut?
And finally I assume all these wires should be connected this is in the part leading up to the switch!
Any help is greatly appreciated :smiley:
Re: Electric mirror wiring
« Reply #1 on: 29 June 2006, 13:35 »
Here you go:
The brown wire goes to the earth 'claw' near the gearbox, the black/yellow wire goes to an ign live source, and the Green/white wire needs to be spliced into the heated rear screen feed somewhere.
Forget all the other wires, they are to do with plugging into the cl/leccy window loom.
Edit:
blk/yel = fusebox D/11
wht/grn = fusebox K/12
See:
http://www.bentleypublishers.com/tech/vw/bentley.vw.fuse.panel.rear.1989-1997.htm
« Last Edit: 29 June 2006, 13:41 by rubjonny »
Offline Red8v
« Reply #2 on: 29 June 2006, 15:08 »
Cheers jonny you are an absolute legend is there anything you don't know? You should work on comission! :grin:
Just wanted to check 1 thing, behind my fuse box there appears to be a few 'spare' female earth connectors could I attach the brown earth to here?
Judderi
« Reply #3 on: 29 June 2006, 15:54 »
Them connectors are most likeley to be live wires so check them before using them!
« Reply #4 on: 29 June 2006, 21:52 »
If the wires are brown they're earth points.  If not then they arn't!  But there is a special earth 'claw' for the purpose, its a metal bracket with a load of spade terminals on it.  Has loads of brown wires running to it, cant miss it ;)
Offline Haribo!
« Reply #5 on: 29 June 2006, 21:58 »
he dosent know what a 'Diaphragm pressure valve' is for  :wink: :laugh:
