Author Topic: Braided brake lines  (Read 2575 times)
Re: Braided brake lines
« Reply #10 on: 30 June 2006, 14:15 »
Yes definitly :)
Judderi
« Reply #11 on: 30 June 2006, 14:17 »
What makes you so sure? Arnt G60 calipers further away needing a longer line?
« Reply #12 on: 30 June 2006, 14:36 »
Well the 16v 256mm caliper hose is actually 35mm shorter than the 8v hose, so no problems with them being too short ;)
« Last Edit: 30 June 2006, 15:04 by rubjonny »
Offline blagger
« Reply #13 on: 30 June 2006, 14:57 »
I'm confused as well now.
Looking to put MK3 16v hubs, discs calipers etc onto my MK2. Which kit will I need, 4-line, 6-line ?? I need the banjo connecters on the front will that effect which kit I will need to buy.
Advice on this matter will be greatly appreciated.
--- If everything seems under control, you're not going fast enough. ---
« Reply #14 on: 30 June 2006, 15:03 »
the difference between the 4 & 6 line kits, is simply if the hoses to the rear calipers are included. (i.e. you need a 4 line kit for a car fitted with rear drums, or if you have MK4 rear calipers which require different hoses altogether)
Offline 16vbanger
« Reply #15 on: 01 July 2006, 13:07 »
GSF sell the 6 line kit for about £53 inc VAT :)
gsf must have messed up when we brought ours a few months ago @ £35 for the goodridge ones  :grin:
