Author Topic: 16v airbox change  (Read 4982 times)
Offline Haribo!
16v airbox change
« on: 27 June 2006, 14:06 »
ive taken off my pipercross induction box and got myself a standard one with a vw air filter and then my car wouldnt start, and when it did it would just die, it runs now but i had to turn the idle srew thingy loads and its certainly not running smooth, the only thing thats missing is vacume hoses, heres some pics could anyone enlighten my as to what they go to and weather its whats causing the troublesome running
s anythign else likely to have been afected by this change like the timing or anything like that?
Offline Veedub1989
Re: 16v airbox change
« Reply #1 on: 27 June 2006, 14:13 »
you must have left one of the vacuum hoses off...too much air is getting in. check all the hoses are secure and there are no leaks. you shouldnt have to adjust the screw by much (2-4 turns at most) to idle correctly (~950 rpm).
VW Golf 1989 2.0L 16v
Offline Haribo!
« Reply #2 on: 27 June 2006, 14:20 »
nah didnt take one off, because the pipercross didnt have any vacume hoses on it,  that one on top of the airbox never had one on....
Offline Haribo!
« Reply #3 on: 28 June 2006, 02:18 »
there was an airleak on that massive rubber thingy that clips to the top of the box, works fine now but my lovely gargle sound has gone, which is ok as i dont sound like a subaru now  :smiley: plus it idles and responds alot better and ide say its goes a little... maybe not quicker but definatly easier,
anyone know where those vacume hoses go?
« Reply #4 on: 28 June 2006, 08:33 »
This any help?  Basically look for a blanked off vacuum hose and connect it up!
Offline Haribo!
« Reply #5 on: 28 June 2006, 10:19 »
hmm, no actually, that airbox is different from mine, mine hasa vacume thingy on the side of the bottom part.......
« Reply #6 on: 28 June 2006, 10:24 »
that bit just opens the warm air feed from the zaust manifold shroud, its a small solid plastic hose which joins between the top & bottom halves :)
Offline Haribo!
« Reply #7 on: 28 June 2006, 10:27 »
oh right,well i dont need that one then, whats the one on top of the airbox for.......the metal one
« Reply #8 on: 28 June 2006, 10:33 »
according to the diagram its the 'Diaphragm pressure valve'
No idea what its for though  :grin:
Offline Haribo!
« Reply #9 on: 28 June 2006, 10:36 »
excuse me.... did i just read what that!!! there must be some mistake!!! you have no idea what something is for!!!!!!?????
holy crap, has hell frozen over!
 :smiley:
