Author Topic: power steering  (Read 1484 times)
Offline dubslug
power steering
« on: 26 June 2006, 16:26 »
 :angry: right not happy, it rains all day and then i go to drive home only for the power steering to play up, when turning it feels like it jams and becomes really heavy, any ideas as to why??it only happens in the wet but not all the time
no belt squeal or anything like that, belt is three months old too
plz help its not fun on roundabts
1992 pearl grey 8v
Offline 16v Matt
Re: power steering
« Reply #1 on: 26 June 2006, 16:37 »
Does it only happen when it rains??
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
Re: power steering
« Reply #2 on: 26 June 2006, 16:38 »
I'd check the belt, it won't necessarily squeal when loose especially if its wet, its usually worn belts that squeal
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline dubslug
Re: power steering
« Reply #3 on: 26 June 2006, 16:48 »
as far as i can tell its not loose either
1992 pearl grey 8v
Re: power steering
« Reply #4 on: 27 June 2006, 09:14 »
MK2 PAS is notorious for not being able to put enough tension on the belt, due to bent bolts underneath.
There is also a splash guard you can get which helps prevent the belts getting wet, check out the part numbers thread :)
I got mine off a late Jetta in my local scrappy for some reason it seems VW put all the splash guards on em even if they didnt have power steering, they even got little extra splash guards which go on the bumper under the fog lights!.
Veedubgt18v
Re: power steering
« Reply #5 on: 27 June 2006, 17:58 »
also check the rubber boots on the rod ends where they go into the steering rack are intact cos if they arent water gets in and creates hydraulic lock in the gears in the steering rack causing the dodgy heaviness. used to do it in my old driver in the wet
Offline dubslug
Re: power steering
« Reply #6 on: 27 June 2006, 18:02 »
looks like one of the brackets for the pump has snapped??
could this cause this, belt is still tight
cheers ed will look at them next tiem the old girl is up in the aur again
1992 pearl grey 8v
Re: power steering
« Reply #7 on: 27 June 2006, 18:48 »
let me know which one, I've got most of a kit spare
