Author Topic: has any one got any tips????  (Read 2213 times)
Veedubgt18v
« on: 18 June 2006, 12:42 »
to help me seal my exhaust.
it doesnt seal well were the exhaust (jetex stainless) meets the standard downpipe.i have tried all sorts of stuff from halfords etc including exhaust paste, exhaust bandage and eo on. the problem is where the 2 slots are cut to allow it to be clamped, it blows from those. wat does anyone reckon?
any good tips?
cos the popping is really annoying me now
ta guys
Veedubgt18v
Re: has any one got any tips????
« Reply #1 on: 18 June 2006, 13:03 »
i have just ordered a heavy duty exhaust clamp like this
and im gonna try pasting underneath it and doing it as tight as i can
however if anyone has any tips then feel free........
Offline Mr Blue
« Reply #2 on: 18 June 2006, 18:28 »
weld it shut :rolleyes:
Offline Uruk Hai
« Reply #3 on: 18 June 2006, 20:03 »
As above, when the down pipe went on my first golf the new one just wouldn't seal. It got to the point that I was snapping exhaust clamps trying to do them up tight so in the end I had that welded and it was fine.
Veedubgt18v
« Reply #4 on: 19 June 2006, 17:06 »
yeah i did think of that if the doesnt work then i may do, but can u weld stainless steel to a normal downpipe?
Offline Uruk Hai
« Reply #5 on: 19 June 2006, 17:47 »
I cant see why not, stainless can be a bit harder to weld but at the end of the day your welding steel to steel. A good welder worth his salt should piss it really mate
Veedubgt18v
« Reply #6 on: 19 June 2006, 17:48 »
awesome i may do that then wen i take the head off to do the valves.......
mix
« Reply #7 on: 19 June 2006, 17:51 »
get a welder then and i will do it for ya ;)
Veedubgt18v
« Reply #8 on: 30 June 2006, 16:57 »
vw clamps are the sh!t they are well heavy duty problem solved cheers dudes
Offline AudiA8Quattro
« Reply #9 on: 01 July 2006, 00:15 »
Don't weld it, just use heavy duty clamps.
I had this problem as well with the vr6, i used loads of paste.
Also note that if you overtighten the clamps, the exhaust will not be compressed evenly, ie. it won't be round any more, so won't seal properly. This is what happens with cheap crap clamps.
« Last Edit: 01 July 2006, 00:17 by audi100Quattro »
