Author Topic: Yellow stuff under the oil cap!  (Read 9242 times)
Blue MK2
Re:Yellow stuff under the oil cap!
« Reply #20 on: 14 December 2003, 13:38 »
?135 for the gasket change and skimmed from a specialist?
golfvr6
« Reply #21 on: 14 December 2003, 13:46 »
Sounds cheap, is that with oe parts?
Blue MK2
« Reply #22 on: 14 December 2003, 13:51 »
Found the problem.
The part where the coolant pipes attach to the head have hairline cracks causing the water to run down and sink into the head gasket.
Im going to order the part 2moro from VAG and see if that solves the problem. Think its something like ?13.
Blue MK2
« Reply #23 on: 14 December 2003, 22:28 »
If i fix the small water leak and stop the water soaking into the gasket, can the gasket be saved?
golfvr6
« Reply #24 on: 14 December 2003, 22:43 »
I'm not sure what you mean. Water shouldn't leak on to the gasket. Can you post a pic.
Blue MK2
« Reply #25 on: 14 December 2003, 23:34 »
To me it looks like the water has soaked into the gasket. I ony noticed the yellow stuff when the leak occured.
ill post a pic 2moro. :-\
golfvr6
« Reply #26 on: 14 December 2003, 23:43 »
Ok, i'm sure it will be ok as long as you get it sorted straight away.
golfvr6
« Reply #27 on: 14 December 2003, 23:44 »
If you want your headgasket done then you should talk to this geezer on clubgti. He reckons he can do a headgasket on a vr6 in 2.5 hours. He could probably do yours in 20 mins  :o
cowboys  ::)
Offline Dean
« Reply #28 on: 17 December 2003, 20:14 »
As far as I know, the garage only deal with VW / Audi motors.
Regards.
Dean.
I am just a mere pawn in the great game of LIFE!
