Author Topic: Cleaning out the throttle body  (Read 1589 times)
Offline JULEE
« on: 07 June 2006, 21:39 »
Hi
Can any one give me a detailed description on how to clean out the throttle body and what to use. Piccies would be very help full as I have no idea what the throttle body looks like.
Ta
Julee
 :huh:
Offline monkeyalan
Re: Cleaning out the throttle body
« Reply #1 on: 08 June 2006, 12:10 »
the throttle body is the metal bit at the back/top of the engine to which the big plastic tube from the airbox connects to. to clean it remove the plastic tube and spray in carb cleaner.
Offline chris_Mk3Annivers
« Reply #2 on: 08 June 2006, 14:32 »
Ahh, great i needed to know that too.. where does the throttle body meet the inlet manifold then..??
i think my symptoms may point to a vacuum leak there.. Tried Haines but cant see a diagram
Offline monkeyalan
« Reply #3 on: 08 June 2006, 15:51 »
from memory it just sits on top of the inlet like a carb would i think.( prepares to be corrected)
Offline Len
« Reply #4 on: 08 June 2006, 16:27 »
The throttle body is or rather becomes the inlet manifold.
www.sas.org.uk
www.the-ace.org.uk
Offline N_GTI_96
« Reply #5 on: 06 July 2006, 15:29 »
hi ya
I just added an old posting I cam accross for this./..
I've to find out how to insert an image though...
see  "How to clean the trottle Body"
hope it helps,
I didi it and it cleared the cutting out issue I had...
Engine would cut out when idling, or changing gear if the gear change was slow,
cool
N:)
