Golf mk2
Mk2 Golf/Jetta GTI Bentley workshop manual
5
6
7
Topic: Mk2 Golf/Jetta GTI Bentley workshop manual (Read 21760 times)
richandhazel
Global Moderator
Forum addict
Re:Mk2 Golf/Jetta GTI Bentley workshop manual
Reply #50 on:
13 December 2003, 12:50 »
I got the ETKA from edonkey too. First one I downloaded didn't work, but the second one did.
The online ETKA is here:-
http://www.elcats.ru/audivw/
Blue MK2
Guest
Reply #51 on:
13 December 2003, 12:52 »
What download was it rich?
I downloaded ETKA Full version 6.1.exe or sumthing?
Is there a special way of installing it off edonkey like the bentley?
richandhazel
Global Moderator
Forum addict
Reply #52 on:
13 December 2003, 12:58 »
I dowloaded ETKA 6.02. It download as an ISO file,I used winace to extract it. You install the ETKA and then run hardlock.exe
Hope that helps.
Diluxe
Here all the time
Reply #53 on:
13 December 2003, 18:48 »
whats ETKA, i want it everyone else has it
1997 16V
Blue MK2
Guest
Reply #54 on:
13 December 2003, 20:07 »
ETKA is the VW/AUDI etc etc parts cd that your local vw/audi dealer uses for parts/part numbers.
I want as it has the diagrams of how the car/parts are put together.
Diluxe
Here all the time
Reply #55 on:
14 December 2003, 02:45 »
So were's all you peeps dowloading from,i never heard of edonkey?
Last Edit: 14 December 2003, 02:45 by Diluxe
1997 16V
VW2010
Reply #56 on:
14 December 2003, 11:23 »
Quote from: Diluxe on 14 December 2003, 02:45
eMule can be downloaded from various sites but I used this one
http://www.emule-project.net/
If you're familiar with Kazaa, then you should be OK with eMule, if you've not used p2p file sharing before there's a good FAQ on the above site!
Blue MK2
Guest
Reply #57 on:
15 December 2003, 10:34 »
Ive just downloaded it. large file!
Still trying to install it as i got an error about my screen resolution.
Anyone know how to overcome this? Ive changed the screen resolution etc wil no effect?
Last Edit: 15 December 2003, 11:48 by Blue MK2
richandhazel
Global Moderator
Forum addict
Reply #58 on:
15 December 2003, 14:54 »
I had that problem on my laptop. Thats running at a resolution of 1024 x 768
Didn't have the problem with my desktop which is running at 1280 x 1024
Doesn't it flash up with a message giving you the minimum resolution required to run it?
Blue MK2
Guest
Reply #59 on:
15 December 2003, 15:51 »
yeah it does but then i adjusted the reolution and it still gives me that error.
Do i unpack the ETKA first then the hardlock program after?
I did that but after the hardlock program finished it came to a setup program and vanished
Last Edit: 15 December 2003, 15:51 by Blue MK2
5
6
7
Golf mk2
