Author Topic: Mk2 Golf/Jetta GTI Bentley workshop manual  (Read 21741 times)
Blue MK2
Re:Mk2 Golf/Jetta GTI Bentley workshop manual
« Reply #10 on: 11 December 2003, 19:49 »
yaeh mate done that. unzipped them using winrar. ill give it another try later
Offline richandhazel
« Reply #11 on: 11 December 2003, 19:53 »
Hmmmm, I'm sure you'll suss it, maybe there is something I've forgotten.........good luck.
Someone else must be able to get it to work..........I can't be the only one :-\
« Last Edit: 11 December 2003, 19:54 by richandhazel »
Offline Diluxe
« Reply #12 on: 11 December 2003, 22:33 »
ok I downloaded all the bits stuck it on disc, hit the set up.exe button, now a web page has opened asking me to enter the registration number, if i do this will i get the FBI knowcking at my door fpr copyright infringement ;D
I though this worked of the disc?
1997 16V
Offline Diluxe
« Reply #13 on: 12 December 2003, 08:59 »
ok couldn't wait for a reply, eneterd the 3Q number on th web page that opened up, all i get is a screen with 3 tabs, electrical,search adn another one that i cant remember, when i type in distributor in the search tab it says there is 108 results but then theres no results to click on where am i going wrong?
cheers
1997 16V
Offline Gambit
« Reply #14 on: 12 December 2003, 09:02 »
Have you and Gambit definately downloaded all 15 parts and then unzipped all 15 parts into another folder?
the folder with the unzipped parts should look like this:-
yeah mate i defo downloaded everything, and it installs everything but it cant launch the jrew.exe thing
its something to do with java enabling on my machine i think
im runnin NT4 which is a pile of shoite
ill try it at home on the lappy
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #15 on: 12 December 2003, 09:49 »
Any joy Gambit - got the same problems !!
It uses some wankey JAVA runtime stuff -  grrrrrr -I'll keep trying as this would be fecking useful, any help would be great ...
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline Gambit
« Reply #16 on: 12 December 2003, 10:18 »
i havent been home yet!
what operating system are you running??
im gonna install it on a windows xp machine in work see if that sorts it
« Last Edit: 12 December 2003, 10:21 by Gambit »
  • Valver Bad Boy
« Reply #17 on: 12 December 2003, 10:31 »
I'm running XP and the lastest 6.0.28 of IE - Looks like it uses an older JAVA enviroment and is not compatible with version 6 upwards ...
You can get your hands on the older stuff from SUN but not having much joy - grrrrrrrrrrr - computers eh who'd work with em !!!
Offline Gambit
« Reply #18 on: 12 December 2003, 10:39 »
i just installed it on XP go the same error message about the jrew.exe problem
went into internet option -> advanced and enabled everything
and it worked
Offline Gambit
« Reply #19 on: 12 December 2003, 10:40 »
cheers
now i get this problem!!
