Author Topic: ABS WARNING LIGHT  (Read 1368 times)
Offline shearer27
ABS WARNING LIGHT
« on: 05 June 2006, 14:22 »
Any ideas why and what it means when the ABS warning light comes on? I have noticed a couple of times when breaking a vibration under the breaking foot? Is it going to be a costly problem?
Offline Len
Re: ABS WARNING LIGHT
« Reply #1 on: 05 June 2006, 14:36 »
Possible warped disc.
That could also be causing the ABS sensor to trip out as well.
www.sas.org.uk
www.the-ace.org.uk
Offline monkeyalan
« Reply #2 on: 06 June 2006, 13:58 »
if the juddering is at slow speed then the ABS light is coming on it will probably be a knackerd sensor. £35 ish
Offline Len
« Reply #3 on: 06 June 2006, 21:35 »
Personally I would be more concerned about the cause of the juddering!
Does it pull to one side under braking as well????
www.sas.org.uk
www.the-ace.org.uk
Offline monkeyalan
« Reply #4 on: 07 June 2006, 12:16 »
thats what happens when the ABS kicks in. i shat myself first time it happened to me cos i thought my brakes were falling apart!  :laugh:
Offline V_Arse6
« Reply #5 on: 07 June 2006, 15:34 »
That's just it telling you the ABS is active.  The juddering you feel is the ABS working - as the others say, if you weren't slamming the anchors on (i.e. hard enough to lock the wheels) at the time then you must have a faulty sensor which is reporting a locking wheel when there isn't one.
'95 Mk3 VR6
FK Highsports, Crystal Clear Fogs/Indicators/Repeaters, Mk4 Style Headlights, PiperX induction, Bonnet lifters. (Need to update pic for new headlights)
