Author Topic: Help!! stuck in third gear!!  (Read 6095 times)
Offline andyxpress
Re:Help!! stuck in third gear!!
« Reply #10 on: 12 December 2003, 15:47 »
Re: Oh and you don't want to use a box from an 8v 1800........the ratio's are different.
Ive been offered a 8v gearbox for 60 notes, this seems to me like a nice easy get out to me. Bin the knackered one and fit the 8v, job done.
Are all the 8 & 16v gear ratios different or is it just the 5th gear??
« Last Edit: 12 December 2003, 15:55 by andyxpress »
Offline richandhazel
« Reply #11 on: 12 December 2003, 15:56 »
Don't bin your old box.........I'll have it if you're just going to chuck it.........better still, I should be able to fix it.
« Last Edit: 12 December 2003, 15:57 by richandhazel »
Offline andyxpress
« Reply #12 on: 12 December 2003, 16:16 »
Your welcome to it sir (assuming the breakers don't want it as a exchange unit).
Ill keep you posted
« Reply #13 on: 12 December 2003, 17:10 »
Cheers........I'll fix it and offer it at repair cost to the forum members. Of course you would be top of the list, should you want it back when fixed.
I just want the experience, worked with a few 8V boxes, haven't done a 16V box yet so although not entirely different at least I'll have had the experience.
Plus I need to justify buying all these tools I've just bought for doing them ;D
golfvr6
« Reply #14 on: 12 December 2003, 17:13 »
Where do you find the time to do all this???
« Reply #15 on: 12 December 2003, 17:17 »
I work a 4 on, 4 off shift pattern.......can get a lot done in the 4 off, if I'm not sat at my PC that is........
golfvr6
« Reply #16 on: 12 December 2003, 18:10 »
Hows abouts da pub?
« Reply #17 on: 12 December 2003, 18:15 »
Yep, spend too much time there too ;D Yippee its Friday night ;D ;D
Offline mk1
« Reply #18 on: 12 December 2003, 20:53 »
Rich, why did the 3rd/4th hub overshoot. Look at the selectors for wear and end float on the shaft.
Just a thought, Steve.
« Reply #19 on: 12 December 2003, 20:59 »
Cheers Steve,
The 4th gear synchro ring is damaged. I thought that might be why it had happened. I've checked the selector forks, they're OK.......haven't checked the end float, I'll check that.
