Author Topic: can anyone please help with elec windows  (Read 693 times)
Offline gribsy2006
« on: 03 June 2006, 23:16 »
hi guys right my car has elec windows and the passenger one works fine going up and down but when you take it right down into the door it wont come up again it just makes a clicking buzzing noise. the only way to get it up is to take off the door card and push it up while pressing the switch.
any help would be real appreciated
thanks guys
Re: can anyone please help with elec windows
« Reply #1 on: 04 June 2006, 12:58 »
sounds like the gears in the motor are jamming up if you open the window too far, you could try stripping the motor & re-greasing it?  The other thing you could do is check if theres a stop on it that has broken off or something, or perhaps fit something to stop the window opening all the way?
Offline silkyballs
  • more tea vicker??
« Reply #2 on: 04 June 2006, 13:55 »
when i got my gti the passenger window would open but would take a week to close so stripped out the motor took the casing apart and sprayed white greaase down the cable and with it still plugged in i wound it in and out untill the grease came out the bottom into the part where the goes onto the wheel.put it all back together and heh presto it was all good! :grin:
http://[img]
Offline gribsy2006
« Reply #3 on: 04 June 2006, 23:32 »
ok cheers guys thanks for your help if you have any other suggestions please let me know
