Author Topic: Testing my fuel gauge  (Read 7415 times)
Offline richandhazel
Re:Testing my fuel gauge
« Reply #20 on: 18 December 2003, 01:34 »
I agree with '6 there, you're need to connect the purple/black to earth (brown) rather than a +ve supply. If you connect that purple/black to a +ve supply, you may well do damage to your gauge and or associated components.
As '6 says the sender unit is a variable resistor, so another thing you may want to try is connecting an ohmeter between the two connections on the sender unit itself and measuring the resistance of the variable resistor. Then after you have used some fuel, try measuring it again. I would imagine that with a full tank you will have high resistance and with an empty tank, low resistance.........although knowing my luck it'll be the other way round.........either way you should see a change in resistance as you use the fuel.
« Last Edit: 18 December 2003, 12:21 by richandhazel »
Offline Gozza
« Reply #21 on: 18 December 2003, 09:27 »
Ok thx lads, I will try connecting the wires as you say and see what happens.
Thx for ya help :)
golfvr6
« Reply #22 on: 19 December 2003, 21:11 »
Any luck with it?
Offline Gozza
« Reply #23 on: 20 December 2003, 09:50 »
Not so far matey, gonna try n have a look either today or tomorrow. Bloody raining again at the mo :(.
Will let ya know once I sort it........hopefully  ::)
CHeers
Offline Gozza
« Reply #24 on: 21 December 2003, 18:29 »
had a look today and crossed the two wires as you suggested and nothing, petrol gauge did not even move at all. Any idea if this means my gauge is shafted ??
Also tried to undo the colar on the petrol tank and is well fkin tight :(
Thx
golfvr6
« Reply #25 on: 21 December 2003, 22:28 »
Have you checked where it connects in the dash. Otherwise there must be a wire break somewhere.
« Reply #26 on: 22 December 2003, 15:07 »
Did you try a resistance check at the sender unit? At least that would confirm whether you need to remove that colar or not.
Offline Gozza
« Reply #27 on: 22 December 2003, 21:43 »
Nah I dont have a tester, been meaning to get one for ages. perhaps this is the perfect opportunity !! ;)
