Author Topic: Oil light and buzzer question  (Read 2136 times)
Offline bling
Re: Oil light and buzzer question
« Reply #10 on: 02 June 2006, 21:02 »
I have changed the oil and filter now and i will be going out for a spin in a minute to see if the oil light and buzzer come on.
i wil give you the results later.
Offline bling
« Reply #11 on: 02 June 2006, 23:15 »
Went out for a test drive and all was going well. then it started again! Damm!
i worked out that it only comes on at 2200rpm and if i go below or above this it will stop making the buzzing noise and oil light.
I haver run out of ides what shall i do?
is there a problem with the pressure or is it just the bleeding pcb board?
can someone help shed some light?
