Author Topic: side trims  (Read 3135 times)
Offline nadlad
  • Building Surveyor MRICS
Re: side trims
« Reply #10 on: 03 June 2006, 11:55 »
been quoted £136.13 for all four door mouldings in primer
<<<Big Build Thread>>>
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: side trims
« Reply #11 on: 04 June 2006, 10:03 »
You can buy the trims to be colour coded primed or unprimed, Stuff i have had primed off VW has had to be rubbed down and primed again because of the shocking job
Offline nadlad
Re: side trims
« Reply #12 on: 04 June 2006, 20:07 »
dont suppose soemone could be kind enough to tell me how to get the bumper bits off without damaging the paint work , is there any guides anywhere please.
Offline GazB
Re: side trims
« Reply #13 on: 04 June 2006, 21:57 »
 the easiest way i would have thought so you do not damage paint is to remove the bumper :undecided:
Offline nadlad
Re: side trims
« Reply #14 on: 04 June 2006, 22:33 »
taking front and rear bumper off is hardly easy, there must be an alternate solution to this problem.
Offline GazB
Re: side trims
« Reply #15 on: 05 June 2006, 20:00 »
well :undecided:, it is 40 mins tops
