Author Topic: What year did K-Jet stop being used?  (Read 2383 times)
Offline Neaty
Re: What year did K-Jet stop being used?
« Reply #20 on: 19 October 2006, 20:03 »
well everyday is a school day. What about mark 3 8vs are they the same thing then?
« Reply #21 on: 19 October 2006, 20:10 »
Similar but not identical, somewhere in between I think. They have a MAF like the MK2 system, but early 2e engines dont have a crank position sensor.  The later (ADY?) blocks have a crank position sensor, and a different dizzy & hall sensor (The early 2e dizzies can be used with the MK2 digi fuel injection system if you fit the bottom end, but the later dizzy will not work). Both have a lambda probe as well.
« Last Edit: 19 October 2006, 20:13 by rubjonny »
