Yep, I've done the Peugeot's - 405 Mi16, 309 GTI very good handling, and used on occasion the 205 GTi 1.6 and 1.9's. Apart from the re-worked 16v 1905 alloy unit by Peugeot, and the standard 1598cc 8 valve Peugeot engine, I thought the standard 1905cc actually a Citroen BX unit a bit of a dog, at 5000 rpm plus it sounded like a load of scrap metal screaming around in an old galvanised water tank. Camshaft Jitter was terrible, plus piston slap. For how long did you get 230bhp - 12 months ? then rings, burnt oil like mad, and then a head leak, steam early on from exhaust on cold start, then dry (piston) liners falling down. At 135bhp the engine was a dog, at 230bhp it must have been a nail bomb !
Talking Golf, Hey, how much did you give for the S plate turbo ? sounds like a very lucky bargain.
How much are you spending on all the mods ? you got a budget in mind.
I'm looking to take my standard AUM a 2001/2 model year turbo to around a 190bhp, I only want the extra pull for the open road, I don't want to spend any on exhaust systems or suspension. I'll have to power-up in a straight line ha ha. But then I have the BM for corners.ÂÂÂ
I'm spending quite a lot of money just bringing the car up to spec at only 48k miles. All Discs shot, lousy tyres, sump damaged but serviceable, pads worn, black oil, the normal semi-mineral gunk, plastic base cover under engine torn off, inner front inner wing liner NS split, change all fluids, list goes on. Car looks sweet on top, very sweet indeed and drives very well at normal speeds- but beneath the surface
I don't think the build quality on the MKIV quite lives up to VW's reputation ! But then I'm new to the marque; Look under your car at just 5 years for signs of corrosion. We shall see.
You guys here look after your motors, but a load of turbo jerks just hit the gas till it stops, or brake fade...........
Good luck Allan.
