Author Topic: More help needed  (Read 1867 times)
Veedubgt18v
Re: More help needed
« Reply #10 on: 23 May 2006, 22:29 »
there is no point hitting the redline tho because u will actuallyy be slowing down by that point. i would change gear before the redline to stay in the powerband if i were you. getting a rolling road session will prove this and indicate where is the best rpm to change gear
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #11 on: 24 May 2006, 00:12 »
I very much doubt wether its the timing, or a rev limiter
To me, what you have described is a problem that sounds like it has something to do with engine movement.. when you gun it in 1st gear, you will get excessive engine movement, more so than any other gear, check your engine mountings for excessive movement, split rubber etc. do this by getting someone competant in the car, handbrake firmly applied, bonnet open.With the engine running, 1st gear selected, go up and down on the clutch pedal to get the car "rocking" but not moving off... look at the engine, does it look like its trying to jump out! either way, check the induction pipes on the fuel injection, are they lose, or split in any way that might let them suck in air, excessive movement can pull on these pipes, and also wires! (you have the classic symptoms!) also check if you can get it to go over the redline, by operating the throttle from under the bonnet, if you can, check your pedal for full movement, and no floormat is stuck under it!!... seen it many times!
If none of the above, I would start with a new fuel filter, its possible that your problem could be fuel starvation, (filter blocked) and again, work your way up to the engine, looking for a damaged, or collapsed fuel pipes
Hope this helps
Tom
Offline Rideandy
« Reply #12 on: 24 May 2006, 08:15 »
Thanks for that tom, will check out all that  you said.
Offline Neaty
« Reply #13 on: 24 May 2006, 10:07 »
I think its a common problem with 8 valves, getting the timing sorted seems  to sort of for most. Which reminds me I need to get my dad to get his sorted!
Offline Rideandy
« Reply #14 on: 24 May 2006, 10:55 »
Cheers mate, all advise is very much appreciated.
Any idea how much a good tune up will cost?
Thanks again.
