Author Topic: mfa stuck on 99.9mpg  (Read 15165 times)
Offline muppetsport
Re:mfa stuck on 99.9mpg
« Reply #20 on: 13 December 2003, 16:52 »
any info on where the vacuum pipe would come from on a mfi gti 8v? i cant find itanywhere on the manfiold at all. maybe thats the problem????
from the sacred dojo of muppetsport the grand master shall show us the way.
3rd dann black belt in car modifying. wax on wax off, engine out, engine in.
Offline Diluxe
« Reply #21 on: 13 December 2003, 18:44 »
well my MFA working, no longer showing 99.9 mpg I found the vacuum pipe in the engine bay it had a pinch in it so i fiddled with it and all seems ok ;D
car boke down on the way home though, had to get rac to bring it home and now it wont start :(
1997 16V
Offline muppetsport
« Reply #22 on: 14 December 2003, 14:24 »
where did you find the vacuum pipe at? i been looking for about half an hour last night and decided i couldnt find it. useless i am
Offline Diluxe
« Reply #23 on: 15 December 2003, 09:54 »
on a 16v its near the dizzy, its a white pipe flimsy
1997 16V
Offline Gaved
Re: mfa stuck on 99.9mpg
« Reply #24 on: 28 March 2017, 09:49 »
Hi
Sorry to revive an old thread.
The rubber tube that measures mpg is connected to the back of the speedo but the other end is not connected to anything...im getting a reading of 16mpg randomly but would much prefer to have it all put back together.
Someone posted a picture on this thread of which area the nib should be to plug it back in...anyone able to shed any light? tried yesterday but couldnt find anything obvious. I have an 89 8v digi.
Thanks
Gavin
Offline lemski
  • 16v
« Reply #25 on: 28 March 2017, 15:19 »
If you look where the brave servo pipe goes to the inlet it should be there. Might be teed in might go straight on. It all runs on the same vac system so if you run through you vac lines and cant find any leaking or a t piece. Just tee it in
Offline Gaved
« Reply #26 on: 29 March 2017, 15:59 »
Cheers for that
So so the clear pipes from the inlet needs to go through the bulk head to behind the speedo or should something already be there?
Offline lemski
  • 16v
« Reply #27 on: 29 March 2017, 20:19 »
The clear pipe should go through towards the clocks. From memory. I run a 16v but dont use mfa so its all deleted from the car.
Ill pull the old vac lines out and see if the old lines are labelled. It may help
Offline Gaved
« Reply #28 on: 30 March 2017, 15:23 »
cheers for that you legend! will have a bash later on when iv got some free time :D
Offline lemski
  • 16v
« Reply #29 on: 31 March 2017, 08:14 »
Right. Mine came from the servi pupe to the ecu and is tead into there to go mfa. Dont ask where it goes through to the clocks because i dont remeber. I seem to think if you look in the scuttle maybe under the ecu tray or around that sort of area
