Author Topic: MOT and ABS light  (Read 3184 times)
Offline perd999
MOT and ABS light
« on: 18 May 2006, 11:37 »
hi , on my mk4 golf my ABS light coems on everytime teh car is started and beeps, will it pass its MOT with the ABS fault and also if there is an airbag fault will it pass???
Offline gillo_grumlin
Re: MOT and ABS light
« Reply #1 on: 18 May 2006, 12:16 »
Nope, if the light is on it a failure.
Offline Mr Blue
« Reply #2 on: 20 May 2006, 08:12 »
pull the bulb out :cool:
Offline perd999
« Reply #3 on: 21 May 2006, 11:20 »
so it iwll fail for the ABS warning but what about the airbag light???
Offline Mr Blue
« Reply #4 on: 21 May 2006, 23:05 »
pull that out aswel  :cool:
yes mate that could fail it
Offline Classy6
« Reply #5 on: 22 May 2006, 04:04 »
Instead of messing about with bulbs and stuff, you could actually attempt to fix your ABS. It is relatively simple, being this is the problem. Wheel speed sensors located around the hub are magnetic. Over time, brake dust that contain metal contents will stick to the Wheel sensor as it's magnetic. This buggers up the the sensor. Easy way to fix this problem is to clear that crap off the sensor, all 4 wheels.
This is a common problem, happened to 2 of my cars for this exact reason. Its at least worth a try eh  :wink:
« Reply #6 on: 24 May 2006, 12:29 »
Could also be a loose or broken wire to the sensor on the hub so check these as well.
For the airbag I had an A4 that lit the airbag warning light which the guys at the garage reset at every service. They did this by removing the module that was under the seat in the A4 and cleanning the contacts and it reset. Might be a similar setup in the MK4.
Offline joesixx
« Reply #7 on: 24 September 2007, 17:12 »
roughly how much should a new sensor cost plus fitting costs? ive been quoted £150
Offline billy_vw
« Reply #8 on: 24 September 2007, 17:33 »
i got LEN405 to help change a ABS sensor on my mk4 recently (front left wheel)
Part cost £10 from ebay and about hour or so labour.
There is a really good thread on this forum with pics and everything.
Oh yeh, after changing the sensor, we realised that when i had car fitted with lowered springs, the wires that conected to the sensor
were not clipped prperly into place, so the front wheel was rubbing on the wheels and snapped, So did not need to change sensor really
But only noticed this after the hard work was done
Regards
Billy
MK5 GT TDi
Offline joesixx
« Reply #9 on: 24 September 2007, 18:00 »
hmm, i dont feel confident to do it myself.
