Author Topic: 2.0 16v Conversion  (Read 984 times)
Offline dubmaster77
  • actualy on the road!
2.0 16v Conversion
« on: 16 May 2006, 22:28 »
Hi guys and girls. My mk2 61v has a really rattley timing chain so i figure i should bin it and fit the mk 3 2.0 16v, However I really want to bin the K Jettronic metering head at the same time mainly so i can fit a funky cone filter, Is this possible? and which engine code should i use??? people have so far qouted me ABS, ABU, ABF???? And they should all drop straight in but i wont find out until i have parted with my hard earned!!!!
Any info greatly appreciated.
Cheers!!! :shocked:
K-Jet is my friend!
Offline Agreeable Slick
  • Unit
Re: 2.0 16v Conversion
« Reply #1 on: 16 May 2006, 22:30 »
ABF or 9A are the easiest to drop into the engine bay.
« Reply #2 on: 17 May 2006, 08:51 »
The MK3 2.0 16v lump is an ABF, as is the lump fitted to later SEATS. The ABF comes with digifant injection, so you can ditch the k-jet if you like.  If you have a post 90 MK2 then the engine loom will plug directly into the fusebox and you'll be away!  If its an early MK2 then you'll have a bit more trouble.  In this case you might as well stick a 9a lump in and stick with the k-jet injection, theres nothing wrong with K-jet, its arguably better than the digifant systems!
What I cant understand is why you're bothering with a lowly 16v engine, when you already have a 61v in there, surely its much faster  :grin:
« Last Edit: 17 May 2006, 08:55 by rubjonny »
Offline gti jim
  • return of the vac...
« Reply #3 on: 17 May 2006, 09:45 »
damn.. beat me to it!!  :grin:  :laugh:
