Author Topic: How do you top up gearbox oil mk2 16v please?  (Read 2203 times)
Offline 16v
« on: 15 May 2006, 16:13 »
Hi,
Got a slight leak from the gearbox on my 1990 16v.
Are they a common sump or do they use separate gear oil in the box?
If the latter, how the hell do you top them up?
Thanks and what's the best stuff to use?
Ta
Offline Agreeable Slick
  • Unit
Re: How do you top up gearbox oil mk2 16v please?
« Reply #1 on: 15 May 2006, 16:26 »
Completely different oil to the engine.
There are two plugs on the side of the gearbox on the passenger side, the top one is the fill hole. Require a hex socket to get it out. Or you could unscrew the speedo cable and fill it from there.
Oil to use is 80/90W hypoid gear oil.
Offline 16v
« Reply #2 on: 15 May 2006, 16:43 »
Thanks muchly :cool:
