Author Topic: Clarification of Part - Suspension  (Read 883 times)
Offline bretttuk
« on: 27 April 2006, 21:49 »
Hi there, i am just solving a few issues with my vehicle. An issue was pulled up when it last had its MOT and it appears to be affecting the car now as the suspension feels a little odd and there is also minor clunking on full lock.
The report says : N/S/F Strut Top Bearing Siezing up
I was wondering if someone could clarify the part and what it is and also what part i need from www.vwspares.co.uk so i can order it as i cant see anything of that name.
Car is a 1991 Mk2 Golf 1.8 16v GTi.
Thanks
Brett
Offline Gambit
Re: Clarification of Part - Suspension
« Reply #1 on: 28 April 2006, 09:21 »
you want these
Front Top Mount 1.8 G60 (Heavy Duty)  03456 £7.68 ea
they are G60 items but will fit 16v's also
buy 2 & replace both sides
« Reply #2 on: 28 April 2006, 10:33 »
Part number 7:
from here:
http://www.vwspares.co.uk/product_info.php?products_id=410
You should replace the top nut as well, as its a self-locking item.
Offline bretttuk
« Reply #3 on: 28 April 2006, 13:04 »
Thanks for that, is it a relatively easy job to do ? Me and a mate would be doing and we both like to get stuck into things really , not bothered about a challenge....
anything i need to watch out for or is it just a case of out with the old , in with the new...
Brett
« Reply #4 on: 28 April 2006, 13:24 »
Once you take the top bolt off, jack up the car & remove the 2 bolts holding the strut to the wheel hub. Mark it up carefully or you'll mess up the camber!
Then you'll need to get a spring compressor on it, part #10 is a slotted nut so you'll need a slotted nut tool to remove it.  It is possible to remove without it though, but it makes the job much easier.
If it was me I'd do both sides, and I'd renew the front bump stops while you're there.
