Author Topic: Idle speed.  (Read 2303 times)
Offline Gozza
Idle speed.
« on: 02 December 2003, 13:28 »
Can someone tell me how to set the idle on my 1988 golf gti mark 2 16v. I know where the idle control is on the inlet, but I remember from my last golf you have to disconnect summink and plug summink up.
Can anyone remind me, pics of the bits I need to fiddle with would be superrrrrrrrrrrrrrr :)
Thx
Offline Gambit
Re:Idle speed.
« Reply #1 on: 02 December 2003, 13:44 »
aye disconnect the red wire on the coil to disable the ISV (if your ISV is working the revs will plummet) & disconnect the breather hose on the air box
Offline Gozza
Re:Idle speed.
« Reply #2 on: 02 December 2003, 13:47 »
breather hose, is that the one that branches off to the right and goes along with the ht leads :)
And the wire I need to disconnect is that at the top right if the engine bay ?
Offline Gambit
Re:Idle speed.
« Reply #3 on: 02 December 2003, 13:54 »
no. it comes out of the actual top of the airbox and runs into the front of the block.
the other pipe is the vacumm used by the ISV
have a look here:-
here
its the thick black pipe u see below the injectors on top of the airbox, and running behind the alternator
also this is a good read for setting up a 16v:-
setup a 16v
« Last Edit: 02 December 2003, 13:57 by Gambit »
Offline Gozza
Re:Idle speed.
« Reply #5 on: 04 December 2003, 17:25 »
Not yet tried this, but wanted to keep me post at the top so I dont lose it :)
