Golf mk4
Wazzzer
Rattle on start up
Topic: Rattle on start up (Read 7936 times)
SunnyP
Rattle on start up
02 December 2003, 12:04 »
I get a rattle from the engine on starting the car, it's only when firing it up, it sort of sounds like a diesel firing up...I had a lookl under the bonnet and the cover (the big plastic cover that has the 20V Turbo writen on it) is lose, the top screw (closest the windscreen) is loose and it woblles...I think this causes the rattle...is this plausible or could it be something else?
sorry for all the posts but new to the Golf GTi.
kniterider
Guest
Re:Rattle on start up
02 December 2003, 14:31 »
ive got 20v non turb, no rattle on mine on start up, but ive read something that this is quite common on the mk4 20v's check ukmk4 site from links page
SunnyP
02 December 2003, 15:17 »
Cheers mate, eased my mind, as long as it's a common fault and the engine is not on it's way out..i'll do some investigation over the weekend.
SunnyP
02 December 2003, 15:25 »
Errr.where is the links page? :-[
Peanut
Just got here
02 December 2003, 17:17 »
hey,
I got a 1.8T and mine also makes that diesel sound when i start it up. you had any luck in resolving it?
thanks.
golfvr6
Guest
02 December 2003, 19:20 »
What oil are you using? maybe it just needs a flush and a change.
Peanut
Just got here
Reply #6 on:
02 December 2003, 23:38 »
Mines only 2 months old!!!
Burnsy
GTI forum regular
Reply #7 on:
03 December 2003, 06:49 »
It could be clutch dust in the starter motor which is common on cars with bout 80 k on the clock but nothing to worry about only the noise
85 Quid will get you a new starter motor
kniterider
Guest
Reply #8 on:
03 December 2003, 14:22 »
i think your worrying about nothing!!!, should be ok if that new and then youve got warrenty aswell so RELAX and enjoy!
stuart
GTI forum regular
Reply #9 on:
05 December 2003, 11:13 »
I have a Seat Leon Cupra, 2003 mod with the 1.8T engine, mine does it most, but not all mornings, or if left to stand for a long time.
I think you will find it is 20 hydraulic valve lifters getting the initial fill of oil.
Stu
Stuart Tunstall
Euro Car Parts (LEEDS) Ltd
Tel: 0113 394 5000
E-Mail: tunstall@eurocarparts.com
*10% discount on parts to Golf GTi members*
Golf mk4
Wazzzer
Rattle on start up
