Author Topic: sealed or non-sealed suspension kit?  (Read 1870 times)
Offline AudiA8Quattro
Re: sealed or non-sealed suspension kit?
« Reply #10 on: 26 April 2006, 12:17 »
What about camber? thats easier to maintain if not using an aftermarket strut, also i've never known an insert not to come out.
Offline golfmk2boy
« Reply #11 on: 26 April 2006, 12:41 »
Hi,
I am thinking of getting the blistein kit from eurocarparts.com.  IT says it lowers the car by -40mm.
Since I have a golf gti 8valve which apparently are lowered -20mm already would the kit lower it a further 20mm?
I have 17's on  my golf, and I will be getting g60 arches aswell.
Can anyone tell me whether this will work?
thanks!
« Reply #12 on: 26 April 2006, 13:07 »
camber will be just as adjustible, the holes will be the same size surely. Its the bolts which you can change for more camber adjustment.
« Reply #13 on: 26 April 2006, 14:37 »
Yes camber will still be adjustable, but thats not the point, if you re-use the original strut it will easier to keep to original fitted position with marks, so no camber adjustment will be necessary.
« Reply #14 on: 26 April 2006, 15:03 »
Ah I see what you mean, but if you replaced your suspension with a lowering kit you'll have to get it checked anyway, lining up the marks isn't going to help you!
« Reply #15 on: 26 April 2006, 18:14 »
True, anything more than a 25mm drop would make the marks useless  :smiley:
