Author Topic: 'Mayo' in the oil filler cap  (Read 6924 times)
Offline Stu-1.8T
  • Quit your Jibba Jabba
« on: 22 April 2006, 22:50 »
My wife's 2.0 has got alot of white gunk around the top of the oil filler neck. I know that sometimes this points to a head gasket failure, but i'm pretty sure it's o.k. The cars a 2001 and has only covered 30k. A fair bit of this has been short journey's, but it does get a long run now and again.
Has anybody else had this problem? and could it be a breather pipe that's not working? the car does smoke a little bit out of the exhaust from cold but otherwise runs fine.
Any comments would be appreciated
Stu
Offline Mantamad
Re: 'Mayo' in the oil filler cap
« Reply #1 on: 22 April 2006, 23:37 »
I'm not an expert on Golf's but reading bits here and there, it has been mentioned that the 2 litre can be bad for this. Certain engine designs can be prone to mayo - my previous car, An Astra also had this problem with no head gasket defect. It was always worse in winter.
Black 2002 GT TDi 130
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #2 on: 23 April 2006, 09:21 »
Could possibly be just condensation, or a split hose as said above.  I'd only be thinking H.G. failure if you've got a serious overheating problem.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline >>Mart<<
« Reply #3 on: 23 April 2006, 11:41 »
is it loosing any water check the header tank and also look inside the header tank bottle and see if there is a film of oil on the top
it could be woth giving it a oil change and letting the oil settle to see if any water seperates from it
Offline welshgar
« Reply #4 on: 23 April 2006, 14:11 »
my mate had the exact same problem... 2.0 gti...46k on the clock loads of short journeys.
he took it to vw and they said the oil breather pipe had blocked.
cleaned it, changed the oil and it was ok for another couple of months.
no H.g failure tho'!
hope this helps
Mk4 GT TDi::RS4's::weitec coilies::RCCR::polo mirrors::cream leather::
MK1 1.5 GL Auto restoration....coming along slowly :-(
its not the winning that gives me pleasure....its the taking apart
Offline heywoodgti
« Reply #5 on: 23 April 2006, 14:50 »
 i had a astra mk4 and the head went on that from the water jacket into the cylinder cost me £ 730
but i dont know much about the golfs so can say much but it sounds like the h.g. gone !!!!
Offline GolfGL
« Reply #6 on: 23 April 2006, 17:20 »
Mine gets like that too but is just condesation. If it was HG was gone there would be the same stuff on dip stick and in the water tank aswell.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline Stu-1.8T
« Reply #7 on: 23 April 2006, 23:04 »
Thanks for all your reply's guys.
The car has never overheated and the dipstick is clean. I'll check the water in the header tank tomorrow but I feel more confident that the head gasket is o.k now. :smiley:
Offline Agreeable Slick
  • Unit
« Reply #8 on: 18 May 2006, 01:18 »
Take it for a proper run, and use the full rev range, it will blow everything out of the car and get it running much more nicely. HG is not going to have gone i reckon.
Offline welshgar
« Reply #9 on: 18 May 2006, 07:44 »
i read somewhere that the oil cooler can sometimes degrade causing the coolant a nd water to mix... there is a quick check list/fix for it....i'll try and remember where i saw it.
i still dont think its the HG tho m8y  :undecided:
