Author Topic: Wet arse  (Read 6754 times)
Offline AdamB
  • The Perfect Storm
Re:Wet arse
« Reply #10 on: 02 December 2003, 12:26 »
My hood is only 18 months old, and it still does it. the roof has no guttering, so the water needs to flow somewhere - usually straight onto the seat!!
I thought you said your car was good mate?  :-*
It only drips when you open the door, the seal is good enough to put it through those big American style carwashes, without any problems
I don't own this anymore - I just can't be arsed to change the picture
Offline danhock
Re:Wet arse
« Reply #11 on: 02 December 2003, 13:23 »
mine drips when you open it. And when its closed!!
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline shortcutstu
Re:Wet arse
« Reply #12 on: 13 December 2003, 00:50 »
yeah i no the filling mine leaks too right where you close the roof together at the front and my roof is only just over a year old i have herd that its something to do with the window and some guy says he can fix it but its going to cost i think along the lines of if he can fix it so can i but i dont no how to yet lol so any idea's would be very welcome.
Offline vixteris
Re:Wet arse
« Reply #13 on: 13 December 2003, 02:02 »
cabriolet = wet and always will. I got a new roof 3 months ago and im as wet and cold as it would be walking. love your car. no one on the outside will know your soaking. oh except other mark 1 golf soft top drivers lol
hint: dont offer any girls a lift
Offline chris_virginie
Re:Wet arse
« Reply #14 on: 13 December 2003, 11:41 »
Well me 2. Not fortunate enough to have garage. Car is only used occasionally so has a pool of water on bot seats when I use it. I have some waterproof overcovers which catch most of it but its not ideal. Also the car is very steamy when I drive for the first few miles. Spose I'll just put up with it. Anyone tried changing the rubber seals.GPC do the front and above door seals.
Offline grassracer
Re:Wet arse
« Reply #15 on: 13 December 2003, 15:56 »
Have you tried adjusting the two hooks that clamp the hood on to the top of the screen , you'l nedd a 10mm spanner, an clean all the seals an wipe over with vasaline an then wipe it off with a clean cloth, ive normally found this to work
