Author Topic: jammed door lock  (Read 1047 times)
Offline gti jim
  • return of the vac...
jammed door lock
« on: 22 April 2006, 15:07 »
the driver side door lock decided to jam locked today (right outside the stealership as well, how embarrasing :embarassed:  :embarassed: )
anyway, i can't even open the door from the inside so i'm thinking that it might be the solenoid or something like that??
biggest problem i have at the moment is being able to open the door so that i can at least get the door card off.
any ideas people??  your help as always is very welcome  :wink:
Re: jammed door lock
« Reply #1 on: 22 April 2006, 19:39 »
Only thing you can do is remove the outer windo trim and try to trigger the lock, make sure it is actually unlocked though.  Its a tricky job but eventually it will pop open! You might want to get a spare lock block ready to slap in place.
You havent replaced the lock block recently have you?
Offline gti jim
« Reply #2 on: 22 April 2006, 20:13 »
i haven't replaced anything at all mate..
i can get the door open onto the latch but no further.  the door pin doesn't appear to move (but the lock i guess has turned slightly if i can get it on the latch).  would i be able to trigger the lock when it's like this??
btw - what do you mean by trigger  :embarassed:  :undecided:
cheers for the reply  :smiley:
« Reply #3 on: 23 April 2006, 11:07 »
When you look at the lock mech there are 2 metal fingers on the lock, one locks the door and the other opens the door.  By trigger I just mean bash the one that opens the door till it pops open :grin:
Offline gti jim
« Reply #4 on: 23 April 2006, 16:34 »
sorted  :wink:
the lock was so full of grime it decided to cease.  cleaned up and refitted with a new set on order from tomorrow!!  :smiley:
« Reply #5 on: 23 April 2006, 18:19 »
cool  :cool:
