Author Topic: adjusting dampers on koni suspension  (Read 1768 times)
Offline nosaj26
« on: 21 April 2006, 21:12 »
has anybody had koni ssk kit fitted? if so how do you adjust the rear dampers? mines far too bouncy, the front is easy as its top adjustable but i cant work out the rear and nobody seams to have an answer!!!! if anybody has done this please help
Offline stomper
Re: adjusting dampers on koni suspension
« Reply #1 on: 22 April 2006, 09:57 »
I thought the rear dampers were adjustable off the car on the SSK.
How have you found the kit generally, good quality? Also did you fit it yourself or get it fitted, if so how much?
I've been looking at the SSK for my 16v. Cheapest i've found it is £350 at larkspeed.
2003 Black Magic Bora Sport 1.8T (180)
AMD remap
Milltek Cat-back exhaust
18" BBS RC's
Eibach 30mm Springs with Boge Shocks
Front and Rear V6 4Motion Valances
Offline nosaj26
« Reply #2 on: 22 April 2006, 21:24 »
ok so far, they look spot on sitting the car a lot lower over my 17's, i paid big boys toys £449 and that also had them fitted, my issue is the rear doesnt appear to be on car adjustable and mine is far too bouncy at the back, with 1 person in my tyres hit the trim around the arches on small bumps, even with just me if i hit a bump in the road wrong its hitting, pissed me off really! i want to know how to adjust and how easy this will be, if not im gonna have to go back to big boys toys and ask them to adjust cos its set far too soft.
Judderi
« Reply #3 on: 24 April 2006, 08:32 »
I dont know for sure but i think the rears may not be adjustable on this set. Dont quote me on that though. Best call BBT's and ask.
Offline Greg
« Reply #4 on: 24 April 2006, 13:05 »
I've recently fitted the SSK kit and the rears are only adjustable off the car. You compress them fully, then turn the piston to adjust. You'll have to go back to BBT unless you can do it yourself.
Have a look at my blog for instructions if you want to give it a try.
http://blackgolfgti.blogspot.com
'99 Mk4 1.8T - FMC007p - R-Tech Stage 1 | '97 Mk3 16v | '91 Mk2 16v | '83 Mk1 L
Offline nosaj26
« Reply #5 on: 24 April 2006, 19:06 »
bbt's were as much use as a chocolate fireguard! they want to charge labour for a job which cant of been set up correct in the 1st place. if you check there catalogue or brochure they both state on car adjustable. anyway enough b!tchin - im taking it down local performance centre tmoz, fingers crossed but ride should be sweeeeeet
Offline Greg
« Reply #6 on: 25 April 2006, 10:06 »
Seeing as how you've just had it changed, they should have no issues at all with stiff nuts/bolts so it should all come apart easily. I'd guestimate no more than two hours for the job.
Offline nosaj26
« Reply #7 on: 25 April 2006, 18:03 »
had work done, deafo much better, it was on lowest setting!!! now set abou 3/4 of way. handles much better, no bounce, yay!!
Still one more job to tackle, the trim still catches towards the front of rear arch if hitting a bump. booked in on thurs to have this trimmed back and arch rolled back.
Offline stomper
« Reply #8 on: 02 May 2006, 15:16 »
nosaj
Did you say the £449 included fitting from big boys toys?
Seems very cheap
AMD remap
18" BBS RC's
Offline nosaj26
« Reply #9 on: 02 May 2006, 21:25 »
yes i also had exhaust fitted at time and they were offering free fitting if ya spend over £500 + vat. all i would say is make sure you tell them how ya want it set up!!!
