Author Topic: throttle micro switch  (Read 1887 times)
Offline Diluxe
« on: 21 April 2006, 13:27 »
can someone tell me on this pic where the throttle micro switch is  :laugh:.
cheers
1997 16V
Judderi
Re: throttle micro switch
« Reply #1 on: 21 April 2006, 13:41 »
It the black plastic bit under this metal bit. The switch is a tiny round thing.
Offline Uruk Hai
« Reply #2 on: 21 April 2006, 13:44 »
You just beat me to it !
Offline Gambit
« Reply #3 on: 21 April 2006, 14:24 »
to test if its working hold the throttle open over 2.5k rpm with your hand. then with your other hand push & hold the switch to close it. you should hear the diaphram operate & engine rev's will drop about 1k rpm before bouncing back up. it will bounce for as long as you hold the switch
this tell you the switch is functioning!
Offline Diluxe
« Reply #4 on: 21 April 2006, 17:38 »
Phew its working, thats one less thing to wory about  :grin:
1997 16V
Offline Ali-Mk2
« Reply #5 on: 22 April 2006, 00:47 »
But what does it actually do?
I saw it and assumed it just sent the engine into some "nutcase mode" when you want all it can give. I can tell you it will drink a tankfull in about an hour flat out, but I'm not so sure it's all that switch's fault.
Selling my Golfs and some other bits. http://www.golfgtiforum.co.uk/index.php?topic=54523.0
« Reply #6 on: 22 April 2006, 09:13 »
On a 16v (and early 8v K-Jets) there is an idle switch which tells the engine to reduce the fueling and run in idle mode.
On a digifant MK2 (like yours according to your sig) There are 2 throttle switches, the idle switch underneath which tells the ecu the engine is idling, and a wide open throttle switch on top whihc tells the ecu you're going hell for leather so it chucks more fuel in :grin:
