Author Topic: Stud extractor for engine bed bolts.  (Read 974 times)
Judderi
« on: 21 April 2006, 11:17 »
Does anybody know what size stud extractor i will need in order to extract a snapped engine bed bolt on a valver?
Offline jimbo
Re: Stud extractor for engine bed bolts.
« Reply #1 on: 21 April 2006, 12:55 »
"engine bed bolt " do you mean cylinder head bolt? if so it should be a M11x1.25 i think but double check with GSF or some body  :wink:
aye up me duck!
Judderi
« Reply #2 on: 21 April 2006, 13:00 »
No i mean engine bed or otherwise known as subframe bolt.
Offline Gambit
« Reply #3 on: 21 April 2006, 13:09 »
has the bolt head snapped or the captive nut sheared from the chassis?
Judderi
« Reply #4 on: 21 April 2006, 13:43 »
The bolt head i think. At the moment the subframe is welded to the chassis. Am i gonna have loads of trouble if its the captive nut?
Offline jimbo
« Reply #5 on: 21 April 2006, 14:01 »
If the sub frame bolt head has sheared there should be nothing holding the sub frame on as the bolt passes through the sub frame in to the floor pan....... so the head of the bolt holds the sub frame against the floor pan. if this is the problem then the sub frame can be lowered to exspose the remaining bolt thread which can be wound out with a set of MAC grips or similar......
if its a knacked captive nut i shall have a look on etos or elsawin to see what they can tell me.
aye up me duck!
Offline Gambit
« Reply #6 on: 21 April 2006, 14:21 »
if its the captive nut then you need to get the captive nut rewelded to the chassis. i had to get this done on my old 16v - only cost about £40 if i remember rightly - though i dont exactly know how they done it. i assume it involves cutting a hole somewhere in order to get access to the nut - or maybe there is a bug somewhere that allows access to it
