Author Topic: widetrack  (Read 2214 times)
Offline Organisys
  • Old and Slow...
Re: widetrack
« Reply #10 on: 22 April 2006, 14:50 »
^^^ cgti Me finks !
Offline barkstar
Re: widetrack
« Reply #11 on: 22 April 2006, 15:50 »
Couldn't possibly comment without my lawyers present :lipsrsealed:
barkstar  :nerd:
Offline Organisys
  • Old and Slow...
Re: widetrack
« Reply #12 on: 24 April 2006, 12:39 »
Yeah, you notice i didn't actually hyperlink it !
VeeDubGTI16v
Re: widetrack
« Reply #13 on: 24 April 2006, 15:40 »
the general answer on cgti is 'use spacers behind stub axles' :undecided:
Offline Agreeable Slick
  • Unit
Re: widetrack
« Reply #14 on: 24 April 2006, 16:09 »
you will also find the general answer to be if it's not a gti then get out.
Offline monzablue16v
Re: widetrack
« Reply #15 on: 24 April 2006, 16:28 »
Meow slick :grin: harsh but fair and true :laugh:
Offline barkstar
Re: widetrack
« Reply #16 on: 24 April 2006, 22:45 »
I still reckon one of the Mk3 beams could do the trick and it's got to be a better way of doing things. All the beams are similar except the plates the stub axle bolt's into - which are closer or further from the tube depending on which model and later beams uses a different bush arrangement which is why you might need the plates that bolt into the chassis for them. If you have a local VW scrappy it shouldn't take long to figure out which beam will do the trick. If you do go that route make sure you get a beam with a built in anti-roll bar.
Barkstar  :nerd:
Offline Organisys
  • Old and Slow...
Re: widetrack
« Reply #17 on: 25 April 2006, 13:28 »
^^^^ yeah get one with a rear ARB, and when you are feeling rich, get a rear ARB to suit the donor car, and a front one to suit the passat, then you can tune the handling balance.
H&R or Neuspeed make them
 :smiley:
