Author Topic: MK3 GTI 8v - No Spark!  (Read 10646 times)
Offline stevo
Re: MK3 GTI 8v - No Spark!
« Reply #10 on: 26 April 2006, 15:24 »
I thought i'd update this, for anybody in the future having problems!
Ran VAGCOM and it returned the following after the scan,
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 - - - Intermittent
Anybody know how to disconnect the VW Immboliser??
Steve
Offline daz123
« Reply #11 on: 03 May 2006, 18:50 »
Steve
sorry but no , have you got a spare key to try
Offline stevo
« Reply #12 on: 03 May 2006, 23:06 »
Unfortunately i dont have a spare Key, I've had the dash apart for most of this week testing various signals, i've overridden the VAG Immobiliser + The aftermarket one and it still dont start properly.
I have the the Pinout of the ECU and have been testing all signals and everything seems to check out.
Vagcom is now showing no faults either!! :angry:
all engine bay earths x4 have been cleaned (didnt need it)
My next step is to replace the Ignition switch with the new part and check out everything throttle related.
I will get to the bottom of this and post here for future reference.
Cheers Steve
« Last Edit: 03 May 2006, 23:13 by stevo »
Offline stevo
« Reply #13 on: 03 May 2006, 23:25 »
For information purposes :
This error is usually related to connection problems between the reader(around the Ignition barrel) and the Immobiliser control unit. there is a black DATA cable which connects both and this usually is the cause of the above Error code.
Keywise there is another code which states the error is related to a weak signal or similar.
Offline stevo
« Reply #14 on: 04 May 2006, 13:44 »
 :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
Fixed the b##tard! Ended up having to replace the Red/Yellow cable running down the drivers side of the Car which is the feed from fuse 18 (Fuel Pump). I wasnt happy with the readings i was getting so i tracked the cable route, and found 2 bad reconnections and 2 connections from my current Immobiliser. Bloody Alarm fitters!!!!!
while i was at it i changed the Ignition switch as i had a new one, used this thread as a guide
http://www.golfgtiforum.co.uk/index.php?topic=20801.0
special thanks to nitro :wink: you saved me a lot of hassle with your post
Thanks again to all who tried to help
Steve
