Author Topic: Water warning light  (Read 3977 times)
Offline golf newbie
Re:Water warning light
« Reply #10 on: 05 December 2003, 22:07 »
yea i replaced the level senor thinking at the time no more bloody flashing red warning light how i laughed when it didnt cure it  >:(
Offline Helios_Blue_Valver
« Reply #11 on: 05 December 2003, 23:28 »
mine does the same. I don't worry about it unless I see the gauge creeping up to the hot end. usually stays about half a gauge .
Offline karmakanix
« Reply #12 on: 06 December 2003, 16:23 »
mine flashed until i noticed a small leak in the bottom of the rad (not enough to lose much water or to overheat). swapped rads, light no longer flashed. i think it is triggered by the sender in the 'stat housing, so if you lose a bit of water light flashes.
Offline gozzy
« Reply #13 on: 09 December 2003, 12:14 »
my Light did that and when the car was hot and i turned off the engine it would piss water out of the header tank at the top. The header tanks collapse inside (so im told) replaced mine for 3 pound from the scrapper now its spot on
Offline Golfgal
« Reply #14 on: 09 December 2003, 12:19 »
my light flashes when I'm tired and it knows its gonna p me off. Its obv a power thang coz my rev counter starts playing up at same time.
V5 Beetle owner. I'm just here for the misfire threads....
