Author Topic: Seemed like a good buy at the time !!!  (Read 7552 times)
turbo
Re:Seemed like a good buy at the time !!!
« Reply #10 on: 30 November 2003, 02:15 »
also do you have any oil in your gearbox!
check gearoil by the allen key on the side of the box accesed through the passanger front wheel arch.
as soon as you unscrew the plug oil should start to trickle out if not top it up or change it.
there is a drain plug under the box it is the same allen key plug!
on newer mk 4 golfs theses plugs are replaced by vw special tool ones! >:(
Offline Gozza
« Reply #11 on: 30 November 2003, 20:42 »
I paid ?500 for it and tis quite a tidy mota, has a few problems with bad spray job but nothing noticable unless looking close.  ;D
And with regards to the gearbox. When warm the gearbox is fine, also the crunch only seems to be from 1st to second and then from 2nd to 3rd. Does not do it if I go from 3rd to 2nd tho ?? Would this still suggest mounts ?? :-\
turbo
« Reply #12 on: 01 December 2003, 01:15 »
could be bad gear linkage or low gearbox oil..or at worse it could be the syncros! but i recon its oil related and its low on oil.
also vw boxes are known for their 1st to second gear crunch when cold....
change the gear oil! it helps!
Offline Helios_Blue_Valver
« Reply #13 on: 02 December 2003, 03:25 »
sounds like a hell of a deal to me! as others have said try the synthetic oils. also the selector shaft will help alot of that problem mine was knackered when i bought it and had the shift throw of an old leyland ldf.
Offline Gambit
« Reply #14 on: 02 December 2003, 09:32 »
a mk3 weighted shift rod will help dampen down the crunch also
?12 from VAG
Offline Gozza
« Reply #15 on: 02 December 2003, 13:11 »
?12 from VAG
Can i get the above from euro car parts ? Is it easy to fit/direct fitment ??
Offline Gambit
« Reply #16 on: 02 December 2003, 13:19 »
no you get it from a VW dealer! part number 1H0711183
and its a piece of piss to fit
Offline Gozza
« Reply #17 on: 02 December 2003, 13:56 »
Thanks for the info gambit, does it involve me getting under the car out of interest (silly question I think). Problem is the car is sooooooooo low I cant get it on me ramps :(.
Offline Gambit
« Reply #18 on: 02 December 2003, 14:00 »
no, it attachs between the selector rod on the gearbox, and the relay shaft, and its only two snap pins that hold it on. u can get at it simply by leaning into the engine bay
ill see if i can dig an ETKA pic of the bit ur replacing
Offline Gambit
« Reply #19 on: 02 December 2003, 14:13 »
yuor replacing number 19 of a mk2:-
with number 44 of a mk3
