Author Topic: Oil light flashing on when slowing down.  (Read 1182 times)
Offline Harvemk2
« on: 06 April 2006, 23:10 »
Anyone know a reason for my 1.8 16v oil light flashing on when i slow down? it seems like when im changing down through the gears to slow down the oil light just flashes on quickly then off again it doesnt stay on just flashes once or twice then off again. is it a problem with pressure or something? :undecided:
Offline Agreeable Slick
  • Unit
Re: Oil light flashing on when slowing down.
« Reply #1 on: 06 April 2006, 23:15 »
it is more than likely the oil pickup pipe being full of sh!t, and dropping the pressure for a few secs. Saying that it could just be a iffy sensor, or (which you don't want) the pump itself could be shafted. One of those 3, take your pick.  :undecided:
« Reply #2 on: 07 April 2006, 08:11 »
start with the cheap things (sensors) then work your way up to dropping the sump and replacing the fuel pump :)
If you're slowing down, perhaps the level is low or the baffle has dropped of the end of the pickup?
  • Unit
« Reply #3 on: 07 April 2006, 08:31 »
 :shocked: :shocked: Jonny in which pump mix up shocker!!  :wink: :grin:
« Reply #4 on: 07 April 2006, 08:44 »
gimmi a break its early  :grin:
  • Unit
« Reply #5 on: 07 April 2006, 08:45 »
lost track mate, been up since 10am yesterday, doing exams, revising, and doing assignments. Roll on 3pm when i hand this shizzle in.
