Author Topic: mk2 16v gti misfiring problem  (Read 3438 times)
Offline lisabet34
Re: mk2 16v gti misfiring problem
« Reply #10 on: 07 April 2006, 22:19 »
no there was no misfire before ignition module was changed ,do you think its that???? lisa
Offline jezza16v
« Reply #11 on: 07 April 2006, 22:28 »
Was the ignition module second hand?  :huh:
Offline lisabet34
« Reply #12 on: 07 April 2006, 22:42 »
no from gsf ,and that was the second one as the rac reconded it was faulty !!!!
Offline jezza16v
« Reply #13 on: 07 April 2006, 23:29 »
Well, its possible I suppose, did they send you a replacement before you returned the dodgy one? Do you know anyone local with a 16v who would let you swap modules over for a check? If they're too worried to do that perhaps they would put the GSF one on their's and see if it does the same. Also check all the earth straps from the battery to shell to engine etc. if these aren't making good contact or are missing the system tries to earth through the ignition module and burns it out (so I've read). In what way did the original ignition module fail? Do you still have it?..... Sooo many questions I know, it scares me to death having one of these when I read about all the things that go wrong, I drive it with my fingers crossed.  :grin: :rolleyes:
PS Just to be clear that we are talking about the same thing, the module that you replaced, where is it located?
Offline lisabet34
« Reply #14 on: 08 April 2006, 18:18 »
the module i replaced is on the drivers side of the engine in top corner
Offline jezza16v
« Reply #15 on: 08 April 2006, 20:00 »
Probably black & silver, a bit smaller than fag packet, 'bout £35? Well thats just a transitorised switch which sets off the spark but it is controlled by the larger box of tricks below it which is the main ECU. Whist the ignition module makes the spark by switching the current to the coil on and off (very quickly) the ECU actually controls 'when' it makes the spark and is controlled by RPM, vacuum and temperature......oh god this is getting heavy. :undecided: A small diameter transparent vacuum pipe is fed to the ECU, if this comes disconnected or splits somewhere it can mess the ignition timing up badly especially at higher revs. Also there is a temperature sender on the gearbox end of the cylinder head (there are four senders grouped together I dont know which one it is) which feeds to the ECU, if this is faulty it can also affect the ECU ignition timing. I'm still curious as to how the original ignition module failed, did it just 'stop' working?. If the new ignition module is def OK and it seems you've replaced just about everything else then the problem could be in the main ECU or the bits connected to it. You've spent loads of cash so far, some of it wasted & got nowhere, I could not suggest that you change the ECU, but you might check the vacuum pipe (its a long one) and you might try swapping the temperature sender, if you can figure which one it is!  (Help! someone must know which one it is). You might just have to bite the bullet and take it to a main dealer or VW specialist to sort. What I can't figure is why you should be left with a problem if you replaced a part which was obviously faulty. Maybe the failure in the IM shorted something out in the main ECU........ :sad:
Offline lisabet34
« Reply #16 on: 10 April 2006, 09:10 »
the module that stopped working did just that, so changed it  i came out of work and the engine would just turn over and not fire up , this is when i rang the rac and they eventually said that was the problem. so i changed it and it started  straight away ,so this was the answer (in my eyes), but i noticed a slight miss on my next journey to birmingham which was the next day ,and from this point on my problems began . i have an ecu turning up tomorrow so fingers crossed . thanks for your info it does make sense not something i would have known .once thanks for taking the time to help will let you know lisa
Offline jezza16v
« Reply #17 on: 10 April 2006, 09:51 »
I hope the ECU change works for you, it sounds like another expensive item?  :undecided:
Offline lisabet34
« Reply #18 on: 12 April 2006, 19:18 »
well what a result i have had in last 2 days managed to get my money back on my distributer  :laugh: got an ecu and a genuine vw ignition module off a sound bloke on e bay (he has most parts you could want ) my boyfriend fitted them both and to my amazement the car is going like a dream no poppin or backfiring . would like to thank everyone again for there time to read and reply to my posts thanks lisa  :smiley:
Offline jezza16v
« Reply #19 on: 12 April 2006, 21:13 »
Glad to see you've got it sorted.  :smiley:
