Author Topic: Fuse box replacement MK2 GTI 16v 1990  (Read 1344 times)
Offline Lee Watson
« on: 05 April 2006, 08:55 »
Hi all
Well I Have had a problem with my wipers and internal fan went to my local garage
and the problems seems that there is a small leak somewhere which is making the underside of the fuse box wet.
So I have obtained a second-hand one with a 3 month guarantee (Great) the only problem is when I tried to fit it last night and the fourth connection I tried to put in would not fit because there is a keyway which is cover up.
I checked the part number and there are the same.  :smiley: :smiley:
Has anyone had the same problem?  :angry: :angry:
And if so do I just file the keyway open?  :evil: :evil:
Please help
Lee
Judderi
Re: Fuse box replacement MK2 GTI 16v 1990
« Reply #1 on: 05 April 2006, 08:57 »
What do you mean by keyway? Im not following.
Offline Lee Watson
« Reply #2 on: 05 April 2006, 09:25 »
What I mean by keyway is that on the connector that goes into the rear of the box there is a bit that sticks out and on the hole in the fuse box there is a slot.
« Reply #3 on: 05 April 2006, 12:58 »
The keyway opens when you pull a clip at one end out :)
Edit: The problem is likly to be caused by the x-over relay, its normally a small metal one with 18 printed on it.  Switch on the wipoers and wiggle it about :)
Next fix the water leak, normally a leak on the fusebox is caused by the drainage holes under the plastic scuttle tray being blocked.  Clear these out and check the bonnet release cable grommet, smearing a ton of grease over it normally stops the leak.  In the mean time put a plastic bag over the top of the fusebox to deflect the worst of the water!
« Last Edit: 05 April 2006, 13:02 by rubjonny »
Offline Lee Watson
« Reply #4 on: 05 April 2006, 14:21 »
Cheers I'll give that a go at the weekend.
