Author Topic: URGENT: need a pic of the engine bay of a 1600 driver  (Read 1540 times)
Offline neilgolfboy
asap please.
Offline Lycara
  • Smoothed doors on a driver
Re: URGENT: need a pic of the engine bay of a 1600 driver
« Reply #1 on: 03 April 2006, 17:22 »
Hi just went out and got some pics fotr ya hope it helps :smiley:
« Last Edit: 03 April 2006, 17:24 by Lycara »
minty freash driver,with smooth doors
Offline dbirchall
« Reply #2 on: 03 April 2006, 23:52 »
hi i have a mk2 drivere aswell jus wondering tho i went to the garage the other day and some guy said my engine was from a mk1 because my carb wab wobly (as mk1 are mounted on rubber bushes) and because it had a spring compressed manifold.. and then to top it off i look at your engine bay and the k+n bolt on filter is the oposite to mine yours is vertical mine is horizontal help... it looks the same jus the k an n ... have you bolted it ion dfferent and how can i find out?
Offline neilgolfboy
« Reply #3 on: 04 April 2006, 08:47 »
i am not an expert, but all 1600 drivers had the ruber gasket/plate to mount the carb on.
also, the pic shows a weber carb i think, that is why the k&n is sat differently.
like i say, i'm no expert though
Offline T_J_G
« Reply #4 on: 04 April 2006, 10:06 »
by looking and that and i'm definitely not an expert.
The k and n could/should go horizontal as thenthe oil reather hose would be an easier fit.
Offline Adam_C
  • Mk4 Golf R32
« Reply #5 on: 05 April 2006, 00:51 »
ive got a 1600 driver mate, my K&N is mounted the other way too from what it is in that picture, so you got nothink to worry about there, i will take a pic tomos and post it for you so you can compare.
Offline Haribo!
« Reply #6 on: 05 April 2006, 08:48 »
thats right  :smiley:
yeah thats a weber, can tell from that spring at the back, on a pierburg the filter would point to the drivers wing
