Author Topic: wheel bearings  (Read 3969 times)
Offline alpesh
Re: wheel bearings
« Reply #10 on: 31 March 2006, 09:39 »
I would replace both sides cos u will find that the other side will go soon......
The hydraulic press picture looks right.
Take the hubs to a mechanic and sort him out with beer tokens.
Veedubgt18v
Re: wheel bearings
« Reply #11 on: 31 March 2006, 09:46 »
yeah right thats a bunch of arse. just cos one side goes doesnt meant the other will. i have replaced loads of wheel earings over the years singularly and the opposite side has never failed soon after. they arent connected in anyway so there is no reason why they should. save yourself some money and do just the one side
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
Re: wheel bearings
« Reply #12 on: 31 March 2006, 09:51 »
I find its usually the passenger ones that go, probably due to the bashing they get on all the sodding pot-holes everywhere
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline stan_deezy
Re: wheel bearings
« Reply #13 on: 31 March 2006, 10:04 »
Yep! I agree. It's often just the passenger side that goes and I reckon it's because of potholes (like you said) and getting kerbed on a regular basis.
I'd love a hydraulic press myself but can't justify £199 for something that doesn't get used that often................although if I added up all the money I've spent over the years paying other people with a hydraulic press  :laugh:
Offline T_J_G
Re: wheel bearings
« Reply #14 on: 31 March 2006, 10:34 »
well after ordering that lot yesterday, it's just turned out.
That's prety good!
 :smiley:
Offline AudiA8Quattro
Re: wheel bearings
« Reply #15 on: 04 April 2006, 18:28 »
Have you replaced loads?  :laugh:
Yeah agreed anyway, front wheel bearings are supposed to last the life of the car, in reality they may or may not.
Offline alpesh
Re: wheel bearings
« Reply #16 on: 05 April 2006, 15:19 »
May be..... but I have found that parts (generally) wear out equally.
I replaced a rear wheel cyclinder and two weeks later the other side started to leak. I was screwed cos I had no brakes coming home from work.
So I stuck with the theory to replace everything in pairs. The wheels/brakes operate equally so they are likely to age equally.
Re: wheel bearings
« Reply #17 on: 05 April 2006, 15:37 »
Brakes - yes, they act together and therefore should be matched in performance
Suspension - yes, as above
Tyres - yes again
wheel bearings -don't really do anything other than hold the wheels in place  :smiley:
my dub project:-
Offline SarahD
Re: wheel bearings
« Reply #18 on: 06 April 2006, 13:48 »
Buy the £15 kit, worth it - includes bearings (obviously) , drive shaft nut, tie-rod nut & split pin and spring clips for the bearings which all need to be replaced. The kit is for one side.
You will need a hydraulic press to remove the old bearings from the hub. A hammer will not work - I have been there.
i changed my bearings without a press, use a socket and a big hammer
Re: wheel bearings
« Reply #19 on: 06 April 2006, 13:53 »
Call this man if you're struggling - what does it matter if it only lasts a fraction of its intended life span  :laugh: :laugh: :laugh:
my dub project:-
