Author Topic: Rolling Roads  (Read 5792 times)
anovadose
Re:Rolling Roads
« Reply #10 on: 26 November 2003, 15:24 »
yeah man me apna. is it gala, gora or sula drivin the vr6? Can't say iv'e seen it bout, have u seen a escort convertable yellow standerd cruising bout them ways?
Offline Slim Shady
  • Thrash her like a ginger step child
Re:Rolling Roads
« Reply #11 on: 26 November 2003, 15:29 »
Why do you think your cambers out?
All wheels or just the fronts?
Do you have stock suspension?
Blue MK2
Re:Rolling Roads
« Reply #12 on: 26 November 2003, 16:14 »
Slim,
On my previous tires the front inners where bold. I dont want this to ruin my new ones as the car is low on coilovers.
golfvr6
Re:Rolling Roads
« Reply #13 on: 26 November 2003, 17:15 »
The first thing to check is the wheel alignment if the tyres are wearing unevenly. You can do a basic setting for camber (ie. approx 0 degrees) by using a spirit level. The way to do this is as follow :-
Jack the car up
Remove one wheel
Place the spirit level on the front panel
Lower the jack until the spirit level is level
Place the spirit level on the brake disc
Adjust the disc/strut with the 2 suspension bolts or the balljoint bolts on the wishbone
Do this until the spirit level is level
Tighten bolts
Repeat for other wheel
Hope that helps  :D
« Last Edit: 26 November 2003, 17:16 by golfvr6 »
Offline Slim Shady
Re:Rolling Roads
« Reply #14 on: 26 November 2003, 17:17 »
amazing what you get from the back of cornflake packets these days. . .
 :P
why didn't you turn up last night Mr6?
golfvr6
Re:Rolling Roads
« Reply #15 on: 26 November 2003, 17:17 »
Rear camber and track is non-adjustable. It will only be out of spec due to accident damage, or severe suspension wear.
Blue MK2
Re:Rolling Roads
« Reply #16 on: 26 November 2003, 18:44 »
Thax 4 that, nifty little trick VR. :D
golfvr6
Re:Rolling Roads
« Reply #17 on: 26 November 2003, 21:15 »
I think you want to set the camber very very slightly negative, ie. top of wheel further in than the bottom.
golfvr6
Re:Rolling Roads
« Reply #18 on: 26 November 2003, 21:16 »
 :P
I know all the cornflakes packets   :-*
Couldn't make last night as my wife could give birth to my daughter at any time now. We will have to all meet another time.
Offline miguel
Re:Rolling Roads
« Reply #19 on: 27 November 2003, 11:05 »
ooh, congrats will be in order then! :'( :'(
