Golf mk4
Wazzzer
rattle on suspension?
Topic: rattle on suspension? (Read 1583 times)
wardie
Just got here
26 March 2006, 18:14 »
ive got a golf 98 mk4 turbo. When driving along down a normal road and go over bumps there is like a rattle/ bang comeing from the front? My old man has pushed the car up and down in all four courners and sed its feels ok? My dad knows a bit bout cars but not a expert by all means. So if somebody cud help cus it is doing my sweed in
GolfGL
Re: rattle on suspension?
26 March 2006, 19:06 »
Is it a high mileage car or lowered at all?
Could be an exhaust or a exhaust hanger loose, possibly top mounts on the suspension whihc you can do a quick test on by pushin harshly down on the four corners of the car and listen out for the noise.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Ivor Mk4 Turbo
Forum addict
2014 PP GTi Manual
26 March 2006, 19:09 »
Jack the front wheels up & shine a torch up the spring/shock assembly, & check that the spring's are not snapped, or there's no fluid leaking out the shocks.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'!
227
bhp, KO3-S'd AGU,
R-TECH Spec 2 map
, Forge 007P,
Blueflame Turbo-back
, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines,
TT Short-shifter
, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>>
http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Ivor Mk4 Turbo
Forum addict
2014 PP GTi Manual
26 March 2006, 19:10 »
ps Is the suspension standard?
227
bhp, KO3-S'd AGU,
R-TECH Spec 2 map
, Forge 007P,
TT Short-shifter
GazB
Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
26 March 2006, 19:38 »
Middle exhaust bracket will have broken at the weld, common on MK4, if you shake the exhaust from the back you will hear it. Its hard to see without a ramp, but I'm pretty sure thats what it is
www.newportedition.com
wardie
Just got here
26 March 2006, 20:21 »
cheers for the replys lads. the car is standard without lower suspension and only got 89k on the clock
charri42
Here all the time
Reply #6 on:
26 March 2006, 23:36 »
Could be a snapped susp spring. Mine made that noise, about an inch snapped off the upper coil and rested in the cup type thing on the shock and rattled like mad.
Golf mk4
Wazzzer
