Author Topic: need new sump and gasket  (Read 1328 times)
Offline Adam_C
  • Mk4 Golf R32
« on: 25 March 2006, 10:56 »
howdy fellas, anyone know the part number from eurocarparts or gsf for a sump and gasket for my 1989 mk2 1.6 driver because i have serious leakage im going to get under her today just to doubly check it is the gasket and sump.
cheers chaps
Offline knobby
Re: need new sump and gasket
« Reply #1 on: 25 March 2006, 11:11 »
Check the oil pressure switch.. Bet its that.. I had similar sort of problems with mine.. was totally sure it was the sump that was leaking.. The bottom of the engine was totally covered.. and i mean leaking alot. The oil pressure switch if i remeber rightly is onto of the housing that holds the oil filter on. i assum is the same for the 1.6 as it is with the GTI 8v. Pull the eletrically cap off and see if there is any oil there. the switches are dead easy to fit and very cheap! 2-3 quid.
Knobby
Old VW's never die...they just go faster!
Offline ...joe
« Reply #2 on: 25 March 2006, 11:43 »
drive up there you lazy f**k*r! its only 5 mins away! :laugh: they only list a cork gasket on their website which to be honest are sh!te. go up there and see what they've got is probably best.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
« Reply #3 on: 25 March 2006, 11:59 »
Check out AVS:
http://www.vwspares.co.uk/g2other.php
They even have the rubber sump gasket kit with the bolts you need to fit it :)
Offline Adam_C
  • Mk4 Golf R32
« Reply #4 on: 25 March 2006, 14:36 »
joe mate i aint going to GSF if they only have that sketchy cork stuff, ill order from that vwspares place cheers jonny looks pretty reasonable
Offline monzablue16v
« Reply #5 on: 30 March 2006, 17:29 »
Check out AVS:
They no longer can supply the bolts they are VW only at 23p each. I'll dig the part number out but good qaulity not sure about fit ask me on Sunday :grin:
Offline jethro
« Reply #6 on: 30 March 2006, 22:47 »
i brought my golf, and 300 miles later the oil warning system went mental, had to replace the oil pump.
while you have the sump off, whip off the oil pump, two bolts, make sure its all clean (the fliter for the pump gets clanked up) and give the sump a good clean. do it while you can access it............................
new boy to the vw world, cos i got me a golf gti mk2 8v
need to do a bit of work on her though.............
« Reply #7 on: 31 March 2006, 00:00 »
I'm doing mine on staurday so if it goes according to plan I'll try and get some photos up. Anybody got any advice on doing it ;)
Got a new sump and rubber gasket, 21 new bolts in case I lose one ;) thinking of taking out the oil pump and cleaning it up.
Any advice welcomed
« Reply #8 on: 31 March 2006, 08:28 »
well the haynes tells you how to check the oil pump, so it might be worth looking at that.  Also from bitter experience I'd advise you change your oil cooler at the same time.  Mine went straight after and dumped a load of oil in my coolant :sick:
Veedubgt18v
« Reply #9 on: 31 March 2006, 09:09 »
a couple of the bolts at the back of the sump are a tiny bit of a faff. you need a long socket extension and even then they dont go in exactly perfect, take it easy so you dont round them off or anything other than that its pretty straight forward. the plastic try thing may be brittle tho (inside) so be carefull when pulling it off
