Author Topic: heres a little trick for ya;  (Read 5333 times)
Offline black_vr6
« on: 04 May 2003, 02:28 »
TRY THIS  pull the keys out of the ignition,put ure headlights on full bore,put ure wipers at on position then hold pull ure dip/main beam on and hold it .............ure wipers should work now or fan etc if not hold  ure dip/main beam on again,pretty usefull hey#   not,.
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline 87_PROJECT
Re: heres a little trick for ya;
« Reply #1 on: 04 May 2003, 13:33 »
What...??
first_timer
« Reply #2 on: 05 May 2003, 19:45 »
what does this do?
dont fully understand 8) ??? ::)
Offline black_vr6
« Reply #3 on: 05 May 2003, 23:42 »
not much ,just lets u put on ure wipers,fan without having ure ignition turned on
Offline 87_PROJECT
« Reply #4 on: 06 May 2003, 02:20 »
do you have a set of jump leads:P:P:P
Offline stoat
« Reply #5 on: 08 May 2003, 15:30 »
I found that out on my old mk2.  If you are trying to steal mk2 all you have to do is get in and break the stearing lock and do the above, then just push start it and away you go
MK3 GTI 8V
