Author Topic: sony subs any good?  (Read 8491 times)
Offline modulater
sony subs any good?
« on: 23 November 2003, 00:43 »
I want to get a subwoofer for my car and have a 10 inch sealed box that someone gave to me. It did have  a kenwood sub in it but this was torn when I got it.
What I would like to know is are sony any good as I have heard a XSL1036 and quite liked it and would it go well with the sealed box or is it more suited to a ported box?
Offline Overseer
Re:sony subs any good?
« Reply #1 on: 23 November 2003, 00:46 »
important thing is.. whats the volume of the box?
sealed boxes are safer (coz u cant really blow up the sub that easy...) wheres ported can be better.. but u gotta tune it right
(i've got 2 rockford fosgate 8's in the back of me car.. )
« Last Edit: 23 November 2003, 00:47 by Overseer »
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 23 November 2003, 16:02 »
if  you box is too small your bass will be tighter. I just built mine up without a tape messure. just marked off roughly where I wanted it and got the jigsaw out. f**k it. it sounds sweet as anyway ;D
Veedubgt18v
« Reply #3 on: 23 November 2003, 21:48 »
thats basically what i had done, i had a JL 12' and it rumbled good, had to sell it to buy new car tho  :( :(
JL are quite good you should check them out
Offline Overseer
« Reply #4 on: 24 November 2003, 08:22 »
guy i work with had a 12" JL Audio sub in a mk2 mr2!.. it was in the footwell in a wedge shaped box that the passenger basically had to lay their legs over! lol
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #5 on: 24 November 2003, 09:34 »
I have to be honest, I have always respected Sony for their electronics, but not their speaker manufacture - I have never heard a set of Sony speakers that genuinely impressed.
I would agree with all the other responses - look further afield.
However, until I know what amp you're using/intend to use, I can't give a recommendation. At the end of the day, any box you have can be modified so as to match the subs requirements, so match a sub to the amp, and forget the box for the moment.
Even if the box is really worng for the sub (which I doubt it will be) you can build another one for ?30. However, spend ?150 on a sub that is killed by your amp (because they weren't correctly matched) just because it matches the spec of your box will be an expensive and needless mistake.
I agree with that Overseer and Veedubgti8v that JL are incredible (just look at the amount of sound-offs are won with that gear) but if you intend to use a 25wrms un-branded amplifier that would struggle to stretch the standard fit speakers, then you'll kill it in a day.
The greatest leveller of them all - the Carousel
anovadose
« Reply #6 on: 24 November 2003, 16:52 »
not really, but i got 2 new brand new boxed sony octo-sub for ?50 each! bought them for the miss'es but she wanted rockfords!!
Offline modulater
« Reply #7 on: 25 November 2003, 22:42 »
I'll have a look at some others then, cheers for the advice.
Offline S11EPS
« Reply #8 on: 26 November 2003, 09:31 »
What amp have you got to run your sub/s mod?
Sweet looking car btw
« Last Edit: 26 November 2003, 09:31 by S11EPS »
Offline modulater
« Reply #9 on: 29 November 2003, 21:02 »
I've got a sony XM502 but i was gonna drive my 6X9's with that and then source one for the sub. Kinda keen on sony as I've never had any probs with them and the headunit is sony.
