Author Topic: No power too Coil  (Read 4803 times)
Offline nitro
  • sometimes it just has to be done.....
Re: No power too Coil
« Reply #20 on: 30 March 2006, 09:09 »
sory for the delayed response daz.
just remove the top and bottom shrouds around the column.
use existing shroud screws, the ig' sw' clips into place( or is held in by the wiring plug that goes into it) so you dont need to buy anything really, i cant remember if i said in the earlier thread, but it was about a 3 or 4 mm drill i used, and again check your measurements and angle carefully.
Offline dazultra
« Reply #21 on: 30 March 2006, 13:01 »
Hey nitro,
Ended up going to my mechanic mate in the end, he had a puller to get the collar off the steering column and once that was off, was just a case of undoing the screw and the switch fell out  :cool:
Radio now working again  :nerd:
Offline scotty4
« Reply #22 on: 30 March 2006, 13:19 »
i have had similar problems with my lupo(low revs and cutting out!!!!), got the injector unit?(don't know much about cars) stripped and cleaned the car is running as new.
MK5 GTI BLUE GRAPHITE 3 DOOR
